hatepotholez Posted January 14, 2015 Share Posted January 14, 2015 (edited) Does anyone know what gauge/AWG wire the harness uses? I'm rebuilding all my harnesses now. The Alternator/ Starter are AVS 5 or 10 AWG i'm going to replace all of it with 8 AWG wiring. Finding White/Red wire in a 10 or 8 AWG is almost impossible. I did find 2 places that would do it but you have to buy a minimum of 500'. I purchased white 8 AWG SXL wire and will use a paint pen to mark a red line through it, I will also then put a "WR" label on the wire on both ends. Since the wires are Japanese spec you have to convert to AWG. To do this you need to count the strands and measure each one then look at the AVS chart. Then take a AVS chart and convert to AWG. Here'es the thread I made on classicZ. http://www.classiczcars.com/topic/50631-proper-gauge-for-wiring/ Edited January 14, 2015 by hatepotholez Quote Link to comment Share on other sites More sharing options...
mainboyd Posted January 20, 2015 Author Share Posted January 20, 2015 Here is the Wiring Harness Diagram I put together with all the wires sized from the Black, Blue, Green, and White connectors. Hope this helps. Quote Link to comment Share on other sites More sharing options...
hatepotholez Posted January 21, 2015 Share Posted January 21, 2015 Here is the Wiring Harness Diagram I put together with all the wires sized from the Black, Blue, Green, and White connectors. Hope this helps. Good stuff! Thanks! Quote Link to comment Share on other sites More sharing options...
mr_han_solo Posted January 26, 2015 Share Posted January 26, 2015 Here is the Wiring Harness Diagram I put together with all the wires sized from the Black, Blue, Green, and White connectors. Hope this helps. Are you using a specialty program to make your diagram or just a regular paint program? Quote Link to comment Share on other sites More sharing options...
mainboyd Posted January 26, 2015 Author Share Posted January 26, 2015 (edited) Are you using a specialty program to make your diagram or just a regular paint program? At the time I was putting this together I didn’t have any program/software in my computer to simply create the diagram so I just went with the good old paint program. It wasn't hard to do. I ended up buying a wiring harness in really good condition online for just $50. All the connectors were still there but the alternator one (which I already have) and none of them were brittle. No cut or additional spliced wires. And to confirm that my diagram was accurate I used the harness I bought online and traced the wiring with the diagram and it was all correct. However, I noticed that one of the white wires in the diagram needs to be changed. I'll change it and update the drawing later this week when I have time. I am still planning on restoring the old one after I get the Z running. Edited January 26, 2015 by mainboyd Quote Link to comment Share on other sites More sharing options...
