Toyota 4x4 calipers/vented rotor setups, where to get rotor spacer?
I just been doing some research on this setup, and seen everything mention the Modern Motorsports machined spacer for use. Now I take it that modern motorsports is no more , so what else is out there?
I found this picture on a google search where the person mentioned grade 8 bolts and washers. How durable would that setup be?
If everything is torqued to spec, shouldn't be an issue right?
No.
Do it right. Go search spacers in the vendors forum.  You will find one.
RB26powered, that is temping. I would be down to buy them spacers, but I gotta check my funds.
Miles, i currently don't have a Z yet, but I just like to do research and plan ahead. Wanting pre-75 S30.
I suppose non-vented earlier toyota 4x4 calipers with fresh Z rotors would be good too (wouldn't need spacer), just kinda desire the vented rotors since all my cars have had vented rotors. Heat dissipation is greatly appreciated when canyon carving where braking is required alot.
Edited by Hypertek
