76 280z rough idle after warm up...
New fuel pump, new gas tank, new plugs, new cables, new cap and rotor, notice after it warms up it idles very rough, I spray some starting fluid thru the airflow meter and idles great for 3 seconds any ideas what could be wrong?
Edited by J240ZTurbo
Which sensor did you replace?    It would help if you explained a little more about what exactly is happening.    So it stays on (drives? idles?)  and then you turn it off and when you try to start it again does it crank? does it fire up?  does it die right after it fires up?
If you take note of all these things it can help you and other members help fix the problem.
The white CHT sensor. So I tooked it for a drive around the block and it rides rough, some back firing, wont pick up speed, I moved the timing around and can clearly see the difference if I moved it around; but if I moved the TPS or if I unplug it I see no chages at all. It idles but I can not perfect.
