78zstyle Posted January 6, 2014 Share Posted January 6, 2014 two things: What trans dipstick is that? Can you show me your tranny cooling lines when you get a chance? Quote Link to comment Share on other sites More sharing options...
Slow78z Posted January 7, 2014 Author Share Posted January 7, 2014 two things: What trans dipstick is that? Can you show me your tranny cooling lines when you get a chance? The dipstick is from Lokar. What shots of the cooling lines would you like? I'd be happy to take more shots. The lines from the tranny up to the front of the engine are stock Z28 lines. From there they go into short rubber hoses and then into more hard line that is running along the frame. Quote Link to comment Share on other sites More sharing options...
78zstyle Posted January 8, 2014 Share Posted January 8, 2014 The dipstick is from Lokar. What shots of the cooling lines would you like? I'd be happy to take more shots. The lines from the tranny up to the front of the engine are stock Z28 lines. From there they go into short rubber hoses and then into more hard line that is running along the frame. The stock z28 lines fit properly to the front of the engine area? Quote Link to comment Share on other sites More sharing options...
Slow78z Posted January 8, 2014 Author Share Posted January 8, 2014 Yes sir, the fit great until the front of the engine. After that one of the lines makes a 90 to the drivers side and the two more 90s ending back over to the passenger side. I just cut off those crazy bends and then bubble flared the ends so the hoses wouldn't come off under pressure. Quote Link to comment Share on other sites More sharing options...
Phantom Posted January 28, 2014 Share Posted January 28, 2014 Slow78Z - What does your car weigh? Your 1/4 times are great on the stock tires. I'm trying to figure out why my LS1/T56 that dyno'd the same as yours is a full second slower on 225/16's. Quote Link to comment Share on other sites More sharing options...
Slow78z Posted January 29, 2014 Author Share Posted January 29, 2014 Slow78Z - What does your car weigh? Your 1/4 times are great on the stock tires. I'm trying to figure out why my LS1/T56 that dyno'd the same as yours is a full second slower on 225/16's.It weighed 2860 without me in it on the scale at the track. It is about 3100 with me in it. Our track gets prepped really good being its a NHRA sanctioned track. I think that helps out a bunch. Quote Link to comment Share on other sites More sharing options...
Goat boi Posted July 14, 2025 Share Posted July 14, 2025 Hi I am currently building my 260 Z 5.3 with a 4L60E. My question is what did you use as a transmission mount. Did you custom make one? and is there a way you can share some pictures. Quote Link to comment Share on other sites More sharing options...
toolman Posted July 17, 2025 Share Posted July 17, 2025 What is your Rear End Gear Ratio? You probably should be running 4:11 or lower. Also, what size slicks do you have? Quote Link to comment Share on other sites More sharing options...
