Guest Anonymous Posted June 26, 2002 Share Posted June 26, 2002 I am slowly adding stuff to my 260. I have a decent engine, recently rebuilt and bored out. I have the round carbs, headers, car is lowered and runs well. Where else can I go for performance? What can I do to continue adding speed to my existing setup. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
Mike C Posted June 26, 2002 Share Posted June 26, 2002 Cold air induction, good exhaust past the header, aftermarket coil/ignition box, 3.90 gear set, and the most expensive but most power, cam swap. Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted June 26, 2002 Share Posted June 26, 2002 Not much to add here. A cam would be good, as would exhasut work. 3.90'S will make a big difference. Good luck. Quote Link to comment Share on other sites More sharing options...
Dan Baldwin Posted June 26, 2002 Share Posted June 26, 2002 Perhaps most important, you should figure out what your compression ratio is now, and increase it to ~10:1, more if you've got a cam. Will probably require shaving the head, unless you swap in a 280ZX NA bottom end w/ flat-tops. This gives you torque and power EVERYwhere. '70 - '72 heads are good for CR, as are the N42 and N47 280Z heads, which also have bigger valves. N42 is the only square-port, big valve head that offers good CR. A 5-speed would be good to go with a shorter-geared diff. The 4-speeds have big gaps between the ratios. Z 5-speed has a better 4-5 shift (.864:1 5th), while the ZX box has a much better 2-3 shift but a tallish .745:1 5th. Quote Link to comment Share on other sites More sharing options...
Boobala Posted June 26, 2002 Share Posted June 26, 2002 I've heard good things about the following combo... * 280ZX NA bottom end w/ flat-tops. (Casting Code = F54) --The 280Z (N42) bottom end w/ flat-tops is good enough. * Early E88 Head w/ Larger 280Z Valves. (casting Code = E88) OR, --P90 Head shaved .080" (avoid the P90A head) * and of course, the Cam of your choice. --262/272 For the street (Good from Idle to 6000rpm. Very good from 2500rpm to 4000rpm) --280 degree cam For Auto-cross and what-not.(3000rpm to red-line) --290-310 degree cams For full race only. (anything above 4000rpm) Quote Link to comment Share on other sites More sharing options...
Guest Zpeed Posted June 27, 2002 Share Posted June 27, 2002 3.9 or 4.1 rear, will give u that extra punch get an exhaust if u don't have one.. 2 1/2 or 2 1/4 up to u which u want... get better air filter for the carbs... if u don't already get the 5spd... get the compression to 10.2 or so and add the cam... all u need to beat most stock cars out there... Quote Link to comment Share on other sites More sharing options...
