fallenone121 Posted September 16, 2013 Share Posted September 16, 2013 Okay...I know this will probably be a pointless inquiring but hey if you dont ask you will never know!I have gotten ahold of KnuKonceptz about wiring of different colors and my plan is to pull out the stock wiring on my Z since I will be doing an acid/alcolyne dip anyway...that way I can upgrade the fuse box fully to a modern fuse block with 18 circuits and upgrade to a better gauge of wiring all the way through...What I am curious about is trying to find out what lengths of wiring for the colors presented.I have the wiring diagram but it doesnt show the lengths I will need for the wiring and I would have to pull all of the old wiring first and keep it together in order to get measurements so I figured I should ask first here if anyone happens to have measurements of the wiring for the Z front to rear so I can upgrade it all. Quote Link to comment Share on other sites More sharing options...
Zinpieces Posted September 16, 2013 Share Posted September 16, 2013 (edited) Save yourself a lot of time and buy a premade harness from Kwik-Wire, my preference, or Painless, or Ron Francis and adapt it to your Z. It is really easier than you might think! Edited September 16, 2013 by Zinpieces Quote Link to comment Share on other sites More sharing options...
Miles Posted September 16, 2013 Share Posted September 16, 2013 Search as there are dozens of posts on how to adapt the Painless kit to the 240Z e.g., how to wire the combo switch etc. Quote Link to comment Share on other sites More sharing options...
fallenone121 Posted September 17, 2013 Author Share Posted September 17, 2013 I have a Painless Wiring 18 circuit modern style fuse block (without harness) to replace the original fuse block that was prone to going supernova - which lead me to realize that the wiring itself may burn out. I did use the search function looking for posts regarding wiring but the inherent flaw on search function is wording - if you dont word it precisely you wont find what you are looking for. It certainly makes sense to get a universal harness to go with the fuse block I already have which would only be like maybe 150$ more which is nothing compared to the money I am already pitching into the project.People locally are already astounded at the very thought of a $90k 240Z build xDSad is that I will have to get most all labor done in other states because noone out here seems to know what they are doing. I did research before I chose to go to another engine because people kept complaining that engines along the lines of the L series kept being blown up by local shops.Thank you for the thoughts Quote Link to comment Share on other sites More sharing options...
ilovemyzed Posted September 17, 2013 Share Posted September 17, 2013 People locally are already astounded at the very thought of a $90k 240Z build xD Im far from local, but Tennessee would be astounded at the thought too. In my opinion, rather than paying local shops to do the work knowing that your budget is that high, why not buy someone else's z that was a funded shop build. to think i thought i went over board. If your doing the wiring yourself, and planning to pull your old harness out, then unwrap it and measure wire by wire to get the dimensions and colors of exactly what you see in your head. None-the-less, i am looking forward to your end product. Should be killer. Quote Link to comment Share on other sites More sharing options...
