ISPKI Posted October 15, 2013 Share Posted October 15, 2013 I am ordering some fuse holders for my 77 280z to replace the fusible links for the two small red wires coming off the battery. The fusible links are badly corroded and the plugs are damaged so I figured I would just replace them with an AGU fuse. I think the wire size is 8 gauge but I wanted to check with you guys just to make sure since my electrical system has been messed with by previous owners. I cannot find anything in the FSM regarding what size these wires should be. I was going to order a pair of AGU fuse holders and some 20 amp fuses for it but figured I would check with you guys first. Quote Link to comment Share on other sites More sharing options...
jeffp Posted November 23, 2013 Share Posted November 23, 2013 10 amp will do the trick. Quote Link to comment Share on other sites More sharing options...
