Cheap way to make your own chin lip front spoiler.
I got the idea from one member of the forum about home-made chin lip spoiler. I have a REAR, yes , rear lip bumper from the acura CL 98. The piece goes to bottom end of the rear bumper. I saved this piece  when replaced the cracked bumper for my wife's CL.
It is actually 2 pieces , one short side and one long side. I flipped it up side down and the side went to front of the z. Sorry i didn't take the picture before working on it. Here is some mock up . Hope it can turn out well and will be a cheap way to add stance look to our Z while we are in tight budget. I will finish up this during weekend and keep you guys update.
The CL , you can see the lip underneath of the rear bumper
The mock up Z,still need some adjustment and fit.. . I did cut the long side to match with the short one and cut the leftover for the center piece and that about it , nothing more.
Edited by 9rider
This is the original lips from the CL. I didn't take picture before the cut.1459112_459359400839627_1734885697_n.jpg
Flipped it side way and up side down.
Cut a small pieces to make corner end. Used some JB plastic weld to glue together. Primed .
Wet sanded.
Final prefit..I still need to run some welting and adjustment. I don't know if I have the center piece will make it look better . How you guy think ?  It don't look as bad in person tho,  It was a pita to mount it with the air dam. I should had used silicone or the JB weld but I thought if it F up then I still can take it out easily so I used rivets. I will add some gigantic spacer to prevent the rivet head eating up my airdam. Also will add some aluminum bar support underneath .
Not too bad....   I hope it's held on by more than just tape though...   I've often thought about alternate Rear Spoilers.  The wing from a hyndai Elantra with a couple pegs fabricated to adjust the angle might not look too bad.
Do you have it on your Z?  I am thinking about fab a duck tail too but most duck tail I found are curve not horizontal straight as for the Z hatch.
Naw, I haven't got that far yet, it could be a pretty easy mod.  I'll get to it one day, but first I need to finish getting the Z painted.
