can i run a turbo on a p-79/f-54 non turbo eng???
Hi Guys,
Can I run a turbo on a stock L-28(1983) motor?
The head is a P-79 & the block is a stock flat top piston.
I'm going to run stock S.U.'s
Let me know guys.... thanks
Guest mongrel
Of course you can!
Just get these parts:
Turbo, turbomainfold, fuelpump and efi controleunit from the ZXT.
Get a complete intake mainfol too, it will have injectors, fuelpressure regulator and sensors.
The ZXT has a higer capacity oilpump, but I think yours should do fine.
Oh, I´ve heard rumores of exhaustliners melting on turbocarged P79 heads (non turbo ZX), I dont know if this should be of concern on a low output engine.
I hope you are not planning to turbo thru SU's. It is not clear from your post.
You can pretty much turbo anything, the question is how long will it last. You will have less margin for error with the flat top engine, so be careful with the boost and timing and you should be ok.
I kind of look at things like this. If Nissan thought the flat top piton engine was robust enough, they would not have made a separate piston for the turbo engine.
