Ryan Merrill Posted January 13, 2014 Share Posted January 13, 2014 From my understanding the Aristo 2JZ's oil pan wont clear the rack in my 71 240Z. Are there any other cars other than the Supra for oil pan/pickup sources? Quote Link to comment Share on other sites More sharing options...
oatmilk Posted January 13, 2014 Share Posted January 13, 2014 As far as I know just the Supra 2jzgte is mid-sump with turbo return already there. Everything can be ordered from a Toyota dealership if you want to go that route. Also look on ebay. Quote Link to comment Share on other sites More sharing options...
Ryan Merrill Posted January 13, 2014 Author Share Posted January 13, 2014 Anyone confirm that the SC300 oil pan will work? Quote Link to comment Share on other sites More sharing options...
seattlejester Posted January 13, 2014 Share Posted January 13, 2014 The sc300 oil pan looks to be as far back enough as you can find, the sump is just really big, might have to trim the stock cross member a little bit. I can try measuring the length this week to see if it will fit if you would like. I'm not sure if the oil pickup, dip stick, etc would work with the aristo 2jz though. Quote Link to comment Share on other sites More sharing options...
Ryan Merrill Posted January 14, 2014 Author Share Posted January 14, 2014 (edited) The Aristo pickup wouldn't but the SC300 pick will. It has to be tapped for the oil return for the turbo's but it will work. Tap size is 8 x 1.25mm.Hole size is 20mm. Read more: http://www.clublexus.com/forums/performance-and-maintenance/587137-1997-sc300-2jz-gte-current-swap-step-by-step-4.html#ixzz2qKnH91mF Edited January 14, 2014 by Ryan Merrill Quote Link to comment Share on other sites More sharing options...
seattlejester Posted January 14, 2014 Share Posted January 14, 2014 I was thinking internally, an oil return fitting would be pretty easy to put on any oil pan, kind of nice that toyota left the casting in the non-turbo pans for the oil return as well. Quote Link to comment Share on other sites More sharing options...
Ryan Merrill Posted January 15, 2014 Author Share Posted January 15, 2014 Probably just a cheaper way of building them, but I'm not complaining lol Quote Link to comment Share on other sites More sharing options...
piston Posted January 17, 2014 Share Posted January 17, 2014 I'm using sc300 rear sump. just tap it for oil return. Quote Link to comment Share on other sites More sharing options...
Ryan Merrill Posted January 17, 2014 Author Share Posted January 17, 2014 On 1/17/2014 at 7:33 PM, piston said: I'm using sc300 rear sump. just tap it for oil return. Perfect thanks Quote Link to comment Share on other sites More sharing options...
Avernier Posted January 19, 2014 Share Posted January 19, 2014 There are only two jz oil pans. Front sump, and rear sump. Front sump is on: IS300, GS300, JZX80-JZX110, crowns, corona Rear sump is on Jza70, jza80, soarer, sc300 They are all the same. You will have to drill and tap for non turbo models. Really simple. You need rear sump for an s30/130 Quote Link to comment Share on other sites More sharing options...
Ryan Merrill Posted January 20, 2014 Author Share Posted January 20, 2014 On 1/19/2014 at 4:32 PM, Avernier said: There are only two jz oil pans. Front sump, and rear sump. Front sump is on: IS300, GS300, JZX80-JZX110, crowns, corona Rear sump is on Jza70, jza80, soarer, sc300 They are all the same. You will have to drill and tap for non turbo models. Really simple. You need rear sump for an s30/130 Thanks for the clarification Quote Link to comment Share on other sites More sharing options...
Rubenonamission Posted March 20, 2014 Share Posted March 20, 2014 I found my oil sump on craigslist, give it a try if u haven't. Quote Link to comment Share on other sites More sharing options...
badjuju Posted March 21, 2014 Share Posted March 21, 2014 The cheapest route to new OE Toyota parts: 1. Call the Toyota dealership in Vancouver, WA 2. ask to talk to Mark 3. (I don't think I'm allowed to tell you to join another forum per the hbz rules, but I don't have time to check the rules, so I just won't tell you to join) IF you're a member of CelicaSupra.com's forum and you do #1 and #2 above, Mark will give you an amazing discount. I can't tell you what percentage, but it is most definitely worthwhile. I try to have no questions to ask him\waste his time with because there is no way he is making money selling us parts. I try to just have as precise of a description as possible. Quote Link to comment Share on other sites More sharing options...
Ryan Merrill Posted March 23, 2014 Author Share Posted March 23, 2014 Thanks, I will give that a try! I'm already a member of that forum, I just avn't posted much I used the site for info. Being Canadian should help as well. Quote Link to comment Share on other sites More sharing options...
badjuju Posted April 3, 2014 Share Posted April 3, 2014 Different Vancouver. Think more amphetamine than marijuana. Quote Link to comment Share on other sites More sharing options...
Avernier Posted April 3, 2014 Share Posted April 3, 2014 Ha! Haha...dying over here. Quote Link to comment Share on other sites More sharing options...
Owndapwn Posted April 4, 2014 Share Posted April 4, 2014 On 4/3/2014 at 5:46 PM, badjuju said: Different Vancouver. Think more amphetamine than marijuana. ...God dammit... This is the most accurate statement I've seen comparing two cities of the same name in quite some time.... Quote Link to comment Share on other sites More sharing options...
badjuju Posted April 4, 2014 Share Posted April 4, 2014 rofl Thanks guys. But really though, don't meth around. Quote Link to comment Share on other sites More sharing options...
Ryan Merrill Posted April 7, 2014 Author Share Posted April 7, 2014 (edited) LOL thanks for the humorous correction! Edited April 7, 2014 by Ryan Merrill Quote Link to comment Share on other sites More sharing options...
grayson260z Posted April 15, 2014 Share Posted April 15, 2014 So , because I'm dense, would an oil pan from a GS300 work? Quote Link to comment Share on other sites More sharing options...
