RebekahsZ Posted February 6, 2014 Share Posted February 6, 2014 Post your LS cam specs. Before and after time slips and or dyno charts appreciated. Include spring, lifter and pushrod specs. Video of lumpy sounds too. Include vendor contact info and $ spent. It's cold out, lets do some bench racing. Quote Link to comment Share on other sites More sharing options...
SUNNY Z Posted February 6, 2014 Share Posted February 6, 2014 (former) Vengeance Racing VRX4 228 / 230 .598/.602 on a 112* LSA + AFR 205's and FAST 90/92 =442 / 420 N/A =576 / 617 on a 150 shot New: Tick Performance 21x / 22x .590 / .640 on a 11x (still in limbo) Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted February 6, 2014 Share Posted February 6, 2014 231/242 duration, .605/.607 113 ls. L76, 6 liter with stock LS3 heads and intake, put down 418 rwhp and 386 rwtq all thru a 4L80E pig. Best pass to date with a lousy tight torque converter in need of a re flash. 6.91 at 101.97 with a 1.64 60 ft. 1/8th mile, 10.91 at 127 with a lousy 1.68 60 ft. 1/4 mile. Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted February 6, 2014 Author Share Posted February 6, 2014 Part numbers brands and sources for cam? Sources and brand of rockers and push rods? Do you have a dyno graph, ZFan1? I think those performance numbers are great. Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted February 8, 2014 Share Posted February 8, 2014 (edited) I'll have to check around for dyno graph. I purchased the cam swap package from Geoff Skinner at EPS, he used to own Thunder Racing. Package (comp cams)came with .650 lift double roller springs, hardened pushrods, valve seals, and the cam is his custom grind numbers that he has Comp cams grind for him. I am using the stock roller rockers, the after market ones are noisy as hell from what I have heard. You can do the trunion upgrade on your roller rockers if you are the least bit concerned about failure. Edited February 9, 2014 by Zfan1 Quote Link to comment Share on other sites More sharing options...
WarlordZ Posted February 12, 2014 Share Posted February 12, 2014 On 2/6/2014 at 1:33 PM, SUNNY Z said: (former) Vengeance Racing VRX4 228 / 230 .598/.602 on a 112* LSA + AFR 205's and FAST 90/92 =442 / 420 N/A =576 / 617 on a 150 shot New: Tick Performance 21x / 22x .590 / .640 on a 11x (still in limbo) I wish you could see some of the work Vengeance Racing does on customer's cars. You'd never run anything that says Vengeance ever again. Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted February 12, 2014 Author Share Posted February 12, 2014 At what rpm do you guys set your shift light? Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted February 12, 2014 Share Posted February 12, 2014 Mine is programmed to shift at 6400, rev limiter is 6700. I am going to lower my shift points to 6200 and rev limiter at 6500. There is no need to spin mine that high, it makes no more power and just wears stuff out prematurely. Quote Link to comment Share on other sites More sharing options...
Phantom Posted February 20, 2014 Share Posted February 20, 2014 On 2/12/2014 at 8:30 PM, Zfan1 said: Mine is programmed to shift at 6400, rev limiter is 6700. I am going to lower my shift points to 6200 and rev limiter at 6500. There is no need to spin mine that high, it makes no more power and just wears stuff out prematurely. Totally agree. I studied my dyno pulls when I first got them and realized everything dropped like a rock after about 5,600 on my stock LS1. I figured cam and heads would give me some more but probably not a lot. The runs I've made, confirmed by the but dyne and ET's indicated that shifts at 5,900-6,000 was where I got my best performance. It also keeps me out of the 6,200 rpm rev limiter. Quote Link to comment Share on other sites More sharing options...
mattd428 Posted March 1, 2014 Share Posted March 1, 2014 595/595 242/242 114 here. Sounds good and made good power. Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted March 2, 2014 Author Share Posted March 2, 2014 Mattd428-can you tell us what car dyno'd with that cam before the turbo? Quote Link to comment Share on other sites More sharing options...
mattd428 Posted March 2, 2014 Share Posted March 2, 2014 Never dynoed with that cam. Previous cam dynoed 298hp 317tq at 5300 rpm. Specs on that cam were 513/513 220/220 114. Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted March 4, 2014 Author Share Posted March 4, 2014 (edited) Just got these specs from forum member: litman FTI Street Sweeper HT Cam: 228/232 0.605/0.600 Edited March 4, 2014 by RebekahsZ Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted March 4, 2014 Share Posted March 4, 2014 Sounds like a good fit for you. You have the cathedral port heads right? Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted March 4, 2014 Author Share Posted March 4, 2014 I haven't gotten to the point of selecting a cam for me. I just learned what litman was running in his incredible car, so I posted it up so I wouldn't forget. I don't know if he has the car running yet, but he just sent me a photo packet in the box with the parts he sent me. The mild custom mods he has done are going to blow the forum away! Quote Link to comment Share on other sites More sharing options...
Litman Posted March 5, 2014 Share Posted March 5, 2014 My LS1 with the aforementioned Street Sweeper is making exactly 0 WHP & 0 WTQ and doesn't sound overly mean. In other words the motor is on a cradle while I am block sanding the shell. Quote Link to comment Share on other sites More sharing options...
