winstonusmc Posted March 21, 2014 Share Posted March 21, 2014 Searched a little couldnt come up with much. I am about to install an 81 L28ET crank pulley to use the trigger wheel for my MS3. I tried to install it on my spare motor an noticed that the crank bolt from the 82 L28 is shorter. Where are these longer bolts available from? The crank is way down in the pulley so far no threads engage on the bolt. I assume its deeper to make more room for the trigger wheel. Quote Link to comment Share on other sites More sharing options...
Tony D Posted March 22, 2014 Share Posted March 22, 2014 Unless you had an aftermarket A/C pulley in there, it should fit. Most people use the longer bolt from the KA 24 in conjunction with a far thicker washer to get proper clamping on everything up front. You should consider that. The 81 L28ET pulley is no different thickness wise than an 82 or and 80.... The timing ring is bolted on to the pulley with three bolts and indexed by a nib in the pulley itself. The only difference is what washer you are planning to use, and if the woodruff key got hung up and you're not fully seated as a result. Quote Link to comment Share on other sites More sharing options...
~KnuckleDuster~ Posted March 22, 2014 Share Posted March 22, 2014 MSA sells the short and long bolt. Runs about $5 Quote Link to comment Share on other sites More sharing options...
winstonusmc Posted March 22, 2014 Author Share Posted March 22, 2014 (edited) The middle of the pulley is thicker when you compare them side by side, probably to make room fro the trigger wheel bolts in the center. Its way thicker than the L26 pulley that came off the motor its currently residing on. I will snap a photo of it on monday. All in all, its thicker than both the L28ET pulley thats on the car now with A/C and the L26 pulley. Edited March 22, 2014 by winstonusmc Quote Link to comment Share on other sites More sharing options...
~KnuckleDuster~ Posted March 22, 2014 Share Posted March 22, 2014 I have a new long bolt I never used, I can measure it if you want and mail it to you. Shoot me a PM if you want it. Quote Link to comment Share on other sites More sharing options...
Tony D Posted March 22, 2014 Share Posted March 22, 2014 L26? The first post said L28. Yeah, early/late are different. But the KA24 Bolt and 1/2" thick washer (or more) is the way you want to go. Look up the Extreme280ZXT site on Angelfire. (JeffP) he has the details on the bolt and washer and why you want to use it. Don't be constrained by what was stock, there are better options out there, and in your higher horsepower application, you will want to avail yourself of them! Quote Link to comment Share on other sites More sharing options...
winstonusmc Posted March 23, 2014 Author Share Posted March 23, 2014 The L26 is the old motor that I am using to mock up the setup for the sensor. I have already tried to put the pulley on my L28 thats in my car with the same issue. The last post answered my question though. Quote Link to comment Share on other sites More sharing options...
winstonusmc Posted March 24, 2014 Author Share Posted March 24, 2014 Here are the pics of said pulley. This shows a crank depth of roughly 17mm. Think its not seated all the way? This is the space behind the trigger wheel. This is the L26 pulley with a crank depth of roughly 2.5mm. I dont feel like pulling the L28ET pulley off, but it was the same story. FYI, there are 5 bolts holding the trigger disc on. I estimate that the bolt has to be 15mm longer, thats 57mm of thread vs the 42mm on the L26/28 bolt. Quote Link to comment Share on other sites More sharing options...
Tony D Posted March 24, 2014 Share Posted March 24, 2014 (edited) You didn't go to Jeff's site, did you? Bottom of the Page: "Damper Bolts" http://www.angelfire.com/extreme/280zxt/page22.html Edited March 24, 2014 by Tony D Quote Link to comment Share on other sites More sharing options...
winstonusmc Posted March 24, 2014 Author Share Posted March 24, 2014 I did see that. I was just showing how different the pulley was with the other L26/28ET pulleys. I will order the other bolt later. It just sucks I will have to shorten it. Quote Link to comment Share on other sites More sharing options...
Tony D Posted March 25, 2014 Share Posted March 25, 2014 Automotive Hobby: "Some Assembly Required!" Quote Link to comment Share on other sites More sharing options...
