gompers Posted April 11, 2014 Share Posted April 11, 2014 I was wondering if it can be done easily, as far as I know the only main difference is that the '83 tank is somehow set up to use the digital dash and my '79 has the regular dash. I can't find any nearby for my year but I found an '83 tank in perfect condition. Also I'm doing a v8 conversion if that affects anything, thanks Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted April 11, 2014 Share Posted April 11, 2014 As far as I know all s130 tanks are the same coupes and 2+2's, the sending unit may be different, but you can swap your 79 one in. Quote Link to comment Share on other sites More sharing options...
gompers Posted April 11, 2014 Author Share Posted April 11, 2014 okay thanks Quote Link to comment Share on other sites More sharing options...
stravi757 Posted April 11, 2014 Share Posted April 11, 2014 On 4/11/2014 at 4:21 PM, BluDestiny said: As far as I know all s130 tanks are the same coupes and 2+2's, the sending unit may be different, but you can swap your 79 one in. +1 Quote Link to comment Share on other sites More sharing options...
ZXR_KiD Posted April 19, 2014 Share Posted April 19, 2014 the digital/analog uses the same sending unit, the only real difference other than the dash itself is the harness to the dash, wich will direct swap.should be just fine with plugging it into the car and going. Quote Link to comment Share on other sites More sharing options...
