MaxxAction Posted May 27, 2014 Share Posted May 27, 2014 (edited) Hey guys... I was wondering if anyone knew the differences between the aluminum/iron blocks in the external casting? Specifically the motor mount points. I ask because I got the LS conversion kit from LOJ innovations, which is a great kit by the way, but it was designed around an iron block motor, and I am using an aluminum block. The motor is setting close to two inches high in the front, so the PS pulley hits the hood, and I cannot get the transmission to bolt in. He is going to make sure it is right, so that isn't a problem, I am just trying to figure out the best way to correct it. Thanks. Edited May 27, 2014 by MaxxAction Quote Link to comment Share on other sites More sharing options...
rags Posted May 27, 2014 Share Posted May 27, 2014 Can you post a picture of the motor in the car? I was under the impression that whether iron or aluminum, the mounting points were identical on Gen III and IV motors. Quote Link to comment Share on other sites More sharing options...
blueshark123 Posted May 27, 2014 Share Posted May 27, 2014 That is correct. The motor mount bolt holes/pattern is the same for the 4.8, 5.3, 5.7, 6.0, and 6.2 motors. What motor are you using and what car? Quote Link to comment Share on other sites More sharing options...
NewZed Posted May 27, 2014 Share Posted May 27, 2014 Web page implies it's been tried and tested. http://www.lojinnovations.com/z32%20kit.htm Quote Link to comment Share on other sites More sharing options...
mattd428 Posted May 28, 2014 Share Posted May 28, 2014 Ls motor mount are ls motor mounts doesn't matter size or aluminum or cast. Quote Link to comment Share on other sites More sharing options...
bejbis Posted May 28, 2014 Share Posted May 28, 2014 What are you trying to put the engine in? The only kit listed on their site is a 300zx(z32). This forum is for specializes in S30's. Quote Link to comment Share on other sites More sharing options...
