Tim H Posted June 8, 2014 Share Posted June 8, 2014 I got spark and timing is set at 10° while cranking the engine. But it won't start it trys to fire a couple of times. It seems very rich plugs are wet black smoke coming from exhaust pipe while cranking. What do I have set wrong. Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted June 10, 2014 Share Posted June 10, 2014 Try reducing the cranking pulse width. Quote Link to comment Share on other sites More sharing options...
mattb3562 Posted June 20, 2014 Share Posted June 20, 2014 It should start at that, but mine has preferred 18° on dizzy and edis Quote Link to comment Share on other sites More sharing options...
seattlejester Posted June 20, 2014 Share Posted June 20, 2014 When you say you have it set to 10*, do you mean in the megasquirt settings? Check timing order, then try and run a timing light to see when the spark is actually firing during cranking. Other then the fact you are running ms 2 you haven't given us very much information at all to go off of. Quote Link to comment Share on other sites More sharing options...
