AZGhost623 Posted July 24, 2014 Share Posted July 24, 2014 Anyone ever seen something like this? Its off a 48/45 DCOE Weber on a race build 3.1L setup. Was this an OEM part or something custom fabricated after the fact? Any known history? Quote Link to comment Share on other sites More sharing options...
Tony D Posted July 25, 2014 Share Posted July 25, 2014 Off road racers used those. You can find them on buggies running 44IDF's I forget...something about the amplification signal provided by the booster and when it takes effect. "Shift, Ctrl, Arrow Up, up, up..." Quote Link to comment Share on other sites More sharing options...
AZGhost623 Posted July 25, 2014 Author Share Posted July 25, 2014 I've seen the Porsche venturis with the longer stem, and found history on those pretty quickly but never seen a setup on DCOE's before. Asked around a bit, and this was something that was completely custom made, not an off the shelf oem part. Looking at the nozzle, it looks like its pinched in a bit and flarred out at the end like a rocket nozzle... wonder if it had the same effect Cool vintage stuff either way.... Quote Link to comment Share on other sites More sharing options...
Tony D Posted July 27, 2014 Share Posted July 27, 2014 Likely someone with Porsche (er...VW...) knowledge was applying that to these in an effort to achieve the same thing. When you can't buy it...you MAKE it! Quote Link to comment Share on other sites More sharing options...
johnc Posted July 27, 2014 Share Posted July 27, 2014 From the expert in our shop... When Venturi size is close to the bore size in the carb you lose signal/sensitivity across the mains. These extended nozzles increase the signal/sensitivity and make the carb more tunable. Quote Link to comment Share on other sites More sharing options...
Tony D Posted July 28, 2014 Share Posted July 28, 2014 "something about the amplification signal provided by the booster" I thought that was what I said.... Quote Link to comment Share on other sites More sharing options...
