My 1st Engine Build Ever ( L26 Refresh Log )
Hey Guys my names Joel. I've been on the forum for a few months, browsing and reading a lot. Skimming topics. I've barely scratched the surface on what I wish to learn and things I need to learn, but all in all, tons of good info. around here. Cool stuff in the archive I can't wait to apply to my Datsun as things progress. Clearly I'm a bit reserved posting my personal things but I do document nearly everything. One day I might make an interesting thread; one day. For now I just wanted to share with you all a little bit and maybe inspire someone as I've been inspired. This will be a log covering my first engine rebuild ever. You see, I decided when I bought my Datsun to avoid as many setbacks as possible due to outsourcing, that I'd try to do as much as I could by myself or under watch of a pro. Buying a non-running Z made my step easy and 1st priority....building a reliable heart. So from scrap to key-on here we go!!!!
Just a lil background. I bought my Z and it came with a L28 ( uninstalled ). Engine on a stand, with some quick pre-lim inspections I realized the motor was seized. "No Biggy" I thought to myself, because before I even bought the car I knew a 3.1L build was in the future and that would be the core. I set out on CL to find a replacement but the running engines were scarce and all seemed to be in norcal. The rest just had a sketchy w/ parts or rebuild w/ no receipts caption. I'll pass on those. Anyway, I ended up finding a local L26 w/ some extras for $140 I later when on to sell some spare parts for it netting me a positive $20. It was advertised as running, which I didn't believe that for a sec. but I figured at that price it was worth a gamble to me. Either way I needed an engine and I was prepared to rebuild an engine regardless of who I bought it from.
4c5608b8-52ad-4ab5-832c-152bbae21022_zps
Ready to get this thing underway and see where I stood, I hauled my newly found L26 down to our shop where my buddies and I wrench on Hondas to start my inspection. Off loaded and ready for teardown.
14189175775_5e12bd2c8c_b.jpg 14189178285_bfede2238b_b.jpg 14002506638_eb35fb7a81_b.jpg
I've read a lot of people suggesting to begin with this book so I ordered one up.
Edited by Nite_Grind
Back to business, Just snapping some photos of components and condition of the longblock was in when I bought it. Due to time being of the essence, at least that is what I once though, I began to tear it down so I could inspect it asap and plan the next course of action.
1stly ripped off these flat tops
14002486079_4d6e69a15a_b.jpg 14002542067_e21b1d17ba_b.jpg14185877331_be537fc11c_b.jpg
next the N36 Manifolds, which I later sold
with those items out of the way, next was the exh. manifold. Remember I mentioned earlier the honda guy thing, it did not hot me conceptually until teardown that the exh. and intake were on the same side. #mindblown LOL
smog equipment? BWHAHAHA I scorn thee
More misc. goods I'm not sure I will reuse, also removed. They will be handy templates if I do not reuse them.
Then it was time to take the pan off. If the bearings are/were good I'd just do a bearing slap and install the engine in my car.
somewhere along the timeline I decided to remove the VC. Amongst all the sludge of poor maintenance I heard a hollow part drop...Hmmmm?
that's what it was. A pc. of the oil spray bar
Oil pan off, I began removing rod caps to check the bearings. I only have 5 pics but all the bearings looked good; this might be an actual running engine I said to myself. So I was content on just reinstalling them and torquing them a few ft.lbs extra. All I'd need now is a HG and re-assemble. Of course the conservative way out. How could I explain anything less to the mrs.
d8_zps62fe2551.jpg d9_zpsaa14c9d6.jpg 20140516_132945_zps0f8c37dd.jpg 20140516_132945-1_zps31a7dfbe.jpg d10_zps7b953bde.jpg
  On 9/10/2014 at 6:13 PM, Spyder Z 15 said:
Very cool. Have you checked out EmpireZ yet? Ontario meets first thursday of every month at the Denny's parking lot off of Milliken.
Thanks Spyder. I haven't yet sir. Datsun is out of commission, but as soon as it's up and running I will.  I'm hoping, I can do this all within the next month. On top of this rebuild, I still have to rebuild carbs, get a 3-2 header, clutch and flywheel, transmission mount and mount area repair, on top of rebuilding the current 4spd.
So with the bearings in good shape, I was in high hopes this would be easy, with just a gasket swap. So I pulled the head off. Quiet the carb build up.
Front engine components removed - a lot of sludge, not bad for 30/40yrs of being on the road I guess.
IMG_1900_zps4e89da81.jpg IMG_1899_zpsb6c5db3c.jpg IMG_1895_zps53fae776.jpg IMG_1901_zps6504c559.jpg IMG_1898_zpsf4e9bc91.jpg
It was at this point, when removing carbon from the piston tops I realized, with my OCD I'd be digging a ditch. Yearning for a piece of mind would only mean one thing. REBUILD IT ALL.:cry:
Houston we have contact.  Piston to valve clearance was diminished for a moment in time.
while I thought it out, I'd continue on to strip the block. I knew a proper rebuild would now be mandatory.
paused for a brief moment to inspect cylinders before I continued disassembly.
IMG_1961_zps10e27663.jpg br9_zps6d034a59.jpg IMG_1953_zpsb244b9f3.jpg IMG_1967_zps9a3c51f6.jpg IMG_1966_zpsb4a6d55d.jpg
bearings cast away like my dreams
fancy crank pose
replaced the mains. I Plan to send the block out to get hot tanked, and prep mentally, physically, financially for a rebuild.
  • 4 weeks later...
The building never ends. The more I stare at this machine the more extravagant I wish to be. A quick reality check, and back to earth, I press-on with the fundamentals. While the block is out for cleaning I decided I'd be sending the flywheel to be lightened and resurfaced, some before pics. Not into researching a performance clutch kit right now. Just stay within the realm of wholesome is what I'm after.
letting my boys in on some L6 lovin - poppin freeze plugs
vc5_zps19d703c9.jpg IMG_2009_zpsdbb886b8.jpg vc15_zpsb190ea46.jpg IMG_2013_zps25a77fd2.jpg
sometimes when a man is lonely he gets a lil bit hone-y! 1st pass I ended up doing10fwd 10rev passes - now she's officially ready for the machine shop
Fly being sent out for resurface & lightening
adding these to the parts to be cleaned pile; w/ the others seen above
so I had sent my block out to my friends shop to get hot tanked and cleaned, I guess he's a stickler for properly maintaing the fluids, because all my parts came back dingy. EHHHH! GRRR! Some may say that's what you get for being cheap, but I assure you I wasn't. My intensions were good; to support a friends. Should have went with my first instinct. So in the right hands, and some media blast later WALLLLLAHHH!
L26B5_zps9dfeae95.jpg d2c39b5b-93b3-4be8-934f-74673e29c002_zps IMG_1985_zps20e09ae0.jpg
my old tattered spray bar that's now in a better place
L26B1_zps3b2334a4.jpg c44b5a49-3a1d-458a-909f-ca690496606c_zps IMG_1989_zps360ced5a.jpg
Block and crank return
block001_zps3161c9dd.jpg block002_zps809e482c.jpg block004_zps557996f1.jpg block005_zps1100c388.jpg
while waiting for the head to come back ( apparently it has a bent valve so I will order one up ) I ordered the basics. Timing Components
Gasket Kit
IMG_1931_zpsc3b1f94f.jpg a7399ef6-1d91-48c8-bf4f-6e6e60601e26_zps IMG_1933_zps4eb29429.jpg
freeze plugs. - note do not buy this kit, can be ordered cheaper at your local parts store.
When I bought my timing kit these were in it..... should have checked this part # 1st. :( set back #1 2.8L Rings.... ummm could have sworn I asked them for 2.6L! Grrr These will be going back for sure.
Turbo Oil pump to keep oil psi up, I drive aggressive-ish so might come in handy, while I attack fwy on ramps LOL
engine004_zpsc1d2f5ba.jpg ENKEI005_zpsc199d110.jpg engine006_zpsa0063508.jpg
pistons and rods cleaned up as well
and of course I had to snap some pics of my pit crew ( 2of 3 ), they wouldn't have it any other way.
Some good info. I was schooled on another forum, which is great, that oil pump posted above is not high vol. I'll need to exchange that. I ordered a turbo pump, but guess what, wrong again. So I'll be ordering a KA24DE pump.
As for the build, here's some goodies all cleaned up, and ready for paint.
tolerances006_zpsa186846d.jpg block007_zps45355d09.jpg block006_zpsdef3fb7a.jpg
yes I plan to rebuild the original 4spd. It's all about the datsun experience.
arrival of the achilles heal - ebay member shorted me a few, but is sending me another full pack. ( vandervell rods, clevite main. )
internals1001_zpsa3a0ce4b.jpg internals014_zps67b9b1ae.jpg internals015_zps8facef58.jpg
cough cough round tops have made its way into the build ;)!!! Balance tube will be shaved and welded. Carbs will be rebuilt to compliment the engine.
extras I received
With the block and VC prepped at work I decided to tackle some stuff at home. 4 stages Rattle can enamel.
L26B8_zpsf42fe2de.jpg IMG_1992_zps54f90634.jpg L26B11_zpsa71cee01.jpg l26b13_zpse6e521cb.jpg IMG_1998_zps10628151.jpg l26b15_zpse3b01e82.jpg IMG_2000_zpsbc775738.jpg l26b17_zps7b676352.jpg IMG_2002_zpsb7751c6d.jpg IMG_2014_zpsd9e6dcf3.jpg IMG_2003_zps583e5f55.jpg goodies004_zpsf1400092.jpg
My minions join daddy again. My lil man ( yes I know he's a cute boy LOL ), and daddy's girl.
  On 10/22/2014 at 8:47 AM, V-Fib said:
Which engine/machine shop did you send your block parts to?
I used carquest; formally known as graves.
  On 10/22/2014 at 12:48 PM, Datz44 said:
Totally agree, Nite_Grind.  its all about the datsun experience, just like in 1974.
Well at least as close to it as I can get in a slightly updated form. I know headers are not the purist option but it's a sensible one nonetheless.
  On 10/22/2014 at 12:55 PM, 98blackbell said:
Great story. Keep up the work
Thanks sir, I'll do my best. I have to sort a few things out, as life would have it, so this may slow down a bit.
