TateS130 Posted September 11, 2014 Share Posted September 11, 2014 So I've been doing some research on velocity stacks...nothing gnarly, just enough to get some general knowledge. From what i read there is almost no noticeable power gains BUT the change in sound is apparently very awesome. Is anyone running velocity stacks on their turbos? Are they any downsides? Is it even possible on an l28et since the turbo is not a top mounted one? Quote Link to comment Share on other sites More sharing options...
OldAndyAndTheSea Posted September 11, 2014 Share Posted September 11, 2014 (edited) Not really sure what you are talking about. Are you talking about doing an individual throttle body setup? (3 throttle bodies with stacks leading to a sealed air box, being force fed by the turbo) or just putting a cone/stack on the turbo? Which sounds stupid to me, especially if there is no filter. But then again, I'm no expert. Edited September 11, 2014 by OldAndyAndTheSea Quote Link to comment Share on other sites More sharing options...
TateS130 Posted September 12, 2014 Author Share Posted September 12, 2014 Not really sure what you are talking about. Are you talking about doing an individual throttle body setup? (3 throttle bodies with stacks leading to a sealed air box, being force fed by the turbo) or just putting a cone/stack on the turbo? Which sounds stupid to me, especially if there is no filter. But then again, I'm no expert. I was just talking about the stack on turbo...I'll link you to a photo. http://i782.photobucket.com/albums/yy106/jdmsfl/4d1.jpg Quote Link to comment Share on other sites More sharing options...
Tony D Posted September 13, 2014 Share Posted September 13, 2014 A radiused collector will smooth flow into the turbine, but as noted, it will require some work to get the box to accommodate it with a proper filter in where you need it to be. Quote Link to comment Share on other sites More sharing options...
