280z Dizzy lockout
frodriguezvsi
Yes. Make sure it's phased properly. Before locking the advance set the engine in tdc #1 in the compression stoke. Make sure the point on the reluctor is pointing to the point in the pickup and the rotor' leading edge is pointing to the terminal in the cap at max advance. Setting the timing can be tricky using ms. mine was retarding during accel instead of advancing and it was because if this phasing issue.
It looks like you can do it that way. but See the slots on the 2nd plate/ larger plate of that HEI style Pic??.. You weld, Jb weld, RTV those 2 slots closed so the centrifical advance can't move. The pins in the lowest plate move in the slots causing the advance to move depending on engine rpm's, so if you close the slots up the advance is locked.
