Back at it....
  • Replies 397
Posted Images
SCCA Laguna Race this weekend.
We just sent off a Teen Challenge Miata to the track.
A T4 Miata has an emergency and I must stop for now.....
IMO, something in the fuel tank..... AGAIN!!!!!!
found some debris in the filter screen, but not sure if it was enough to lean out fuel mixture.
maybe there's still fine particles in the tank?
really haven't tuned yet, just adjusted a/f ratios.....
Have too much going on tomorrow......
New valve cover gasket is replaced, but don't think that's where the leak is coming from.....
I bought the wrong tires...
245/45/17. Instead of 40.
I'll give it a try. The tire is a little taller than the rear, so the take is off....
No big deal,
I can just buy the correct ones should this not fit properly .....
close---
master cylinder is bad and front tires were my fault.
spending the rest of the day checking the pinout to the fan and tach.
just changed out main heater hose and swapping out dyno oil for fresh fluids......
new master cylinder should arrive on Monday, tires tuesday and whatever else I can't remember....
We do have to rewire the brake lights, since I have the Euro lenses......
need to figure out the speedo and tach......
I like the classic look of the gauges and don't want to muck this up too much.....
i could easily make a mount and install an AIM stack display, but that would just look funny....
