z ya Posted December 7, 2001 Share Posted December 7, 2001 Hey I was thinking about removing the drain plug in the belly of the gas tank and taping to pipe tread to accept a bulkhead fitting. I would also make a small sheild over the fitting so it could not be ripped off. What do you guys think? I really dont feel right about the 5/16 outlet on a 400+ hp car. Has anyone done this? Thanks z ya Quote Link to comment Share on other sites More sharing options...
fl327 Posted December 7, 2001 Share Posted December 7, 2001 itll work. Quote Link to comment Share on other sites More sharing options...
Guest RXO510 Posted December 7, 2001 Share Posted December 7, 2001 Maybe you can even put in a Y fitting or something so that you can feed the engine, but also drain the tank if you needed to. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted December 7, 2001 Share Posted December 7, 2001 The only thing I would be worried about is dirt that settles to the bottom of the tank and gets into the lines. Make sure you have a filter before the pump. Tim Quote Link to comment Share on other sites More sharing options...
z ya Posted December 7, 2001 Author Share Posted December 7, 2001 Cool, thanks for the input. I am gonna check it out tomarrow. Quote Link to comment Share on other sites More sharing options...
