Cranks and goes to 3000 RPM for 2 sec then cuts off
Hi, I've had my Z for about 6 months now and just started to do some updating and now I'm looking for help. My 78 280 was running fine except for an exhaust leak so I replaced the intake manifold gasket thinking that was the problem While removing the intake and header I found the leak was actually coming from the EGR tube broken at the header. I went ahead and replaced the intake gasket and deciced to just get rid of the EGR as many others have done. I blocked off all the EGR holes to delete it. While everything was apart I decided to replace all vac lines and fuel hoses. Then I decided to clean the throttle body while it was all apart. Got all that done and put back together and went to crank. It cranks but races to 3000 RPM's for 2-3 seconds and then idles down and cuts off if you don't give it any gas. If you give it gas it races back to 3000 RPM's and keeps doing the same routine. Ive checked back over all the plugs and vac lines, the only problem I see is the wire that goes into the bottom of the throttle body where the BCDD is, broke off at the connection where it screws into the BCDD. I'm not sure what you call that sensor and I'm not sure if that would be causing the idle issues or not. Any help would be appreciated.
That wire actually powers the solenoid in the BCDD.  There's no sensor in there.  Did you take the BCDD off or apart while you were cleaning the throttle body?
Sounds like a vacuum leak of some kind.  A leaky BCDD might be the problem.
Crank means engine turning over, or crankshaft spinning.  Crank is what the starter does, it used to be done by a human with a crank handle, that's why people still say crank.  After cranking comes ignition, then starting, then running.
Nope didn't take it apart. I've been going thru the fsm and noticed my air regulator was on backwards and it could cause high idle, turned it around and still same problem. I did check to see if the flap in it would still move and it did. Cleaned the connector to it was corroded, didn't help. I will get my circuit tester from work tomorrow and check the wiring harness.
