Klmykvl Posted April 28, 2015 Share Posted April 28, 2015 I know the simple solution would be to have a drive shaft made to fit my application, but I'm wondering if there is another way to get my driveshaft to fit my setup. I have a 240Z with a T5 Tranny and R180 Diff. I have both the driveline from the 240Z and the 280zx donor car. My question is: Instead of having a custom driveshaft made to shorten the length and fit both the R180 and T5, would it be possible to buy a shorter T5 Slip Yoke and install it on the driveshaft from the 240? I found the following slip yoke online and I think this will work http://www.dennysdriveshaft.com/p252_borg_warner_t_5_t_56_and_t_10_transmission_slip_yoke_1350_se.html Just wondering if any of you have had experience with this. Thanks for any input. Quote Link to comment Share on other sites More sharing options...
Namor Posted May 3, 2015 Share Posted May 3, 2015 The original driveshaft has non-replaceable u-joints, you aren't going to be able to buy this and just slap it onto the driveshaft. I would talk to a driveshaft shop and see what they have to say. Quote Link to comment Share on other sites More sharing options...
seattlejester Posted May 6, 2015 Share Posted May 6, 2015 I want to say the yoke for the nissan T5 is it's own thing and I believe the one you have pictured will not work. If you are cheap you can shorten it yourself if you can/have the abilities do your best to keep it straight, and eyeball the counter weight, be prepared for some serious vibrations. If you don't you can take it to a smaller shop and have them shorten it for you with no guarantees for 50$. Or you can take it to a driveline shop have them shorten and balance it for you for 100-150$. Or you can have a new one made with replaceable joints etc for ~300$. Quote Link to comment Share on other sites More sharing options...
