zmnap Posted July 9, 2015 Share Posted July 9, 2015 (edited) Hey guys, This is the journey of my 1974 Datsun 260z to where it currently stands and where it is headed. I hope you enjoy! This was the car when I first got it... It was a good running car that was fairly "clean" with the exception of some hidden rust. I drove the car like this for a couple of years before I really got the itch to modify it. To start things off, my carbs started leaking so I rebuilt the round top already on the car. The outcome: Nice new carbs and a sad looking engine bay. (Ignore the wheel in the background, we will get to those later...) With the production of the BC Racing coilovers, I decided it was time to pull the car apart for a few updates in the winter of 2014/2015. It would share a space with an old Austin Healey Mini for the winter. With it up on Jack stands, the intentions were to go through the bushings, suspension and address the rear brakes. Along the Way I also picked up a set of Wilwoods for the front which are still having brackets fabricated. I acquired a Silvermine rear disc brake conversion, BC Racing coilovers, & some Prothane Bushings and work began. With all of the parts acquired that I wanted/needed for the winter ahead, I came across a pretty rair set of wheels that I would snatch up: 15x9 3-Piece Revolution RFX's that the previous owner had painted the faces of a House of Kolors Green. At first, I hated the color of the wheels but they have since grown on me a bit. With everything ready for the winter project, I started tearing the car apart... [/url With all of the suspension pulled off and the struts sectioned, I started assembling the front coilovers. The shop I had weld them had some pretty ugly welds that I ended up having to grind down. I also wire-wheeled the knuckle assembly and painted it for a nice finished look. I also went on ahead and wire-wheeled and painted the brake dust shields while I was at it... Finished Products: Edited July 10, 2015 by zmnap Quote Link to comment Share on other sites More sharing options...
zmnap Posted July 10, 2015 Author Share Posted July 10, 2015 The Rears weren't so forgiving... The spindle pin did not want to cooperate so I sent it to a shop to have them press it out, sandblast the rear hubs, and press some new wheel bearings. I also changed out my rear studs for Nissan Quest studs as a cheap way of getting a few extra MM for my lugs to bite onto. With the rear spindle removed, the threads had to be cleaned up as well. A big thanks to MWorks garage who did a killer job on the parts for me! Finished Products: Quote Link to comment Share on other sites More sharing options...
