Hypertek Posted July 22, 2015 Share Posted July 22, 2015 Hey guys, i just wanted an opinion on my mounting location. I cut the original pump bracket (early 260z), and mounted the pump here for now, but was just curious on the fuel hose routing.. if it was ok to have the hose wrap around that far out towards the wheel. Or should I try to mount it more towards the center? Suggestions and advice appreciated. Thanks! Quote Link to comment Share on other sites More sharing options...
lester Posted July 22, 2015 Share Posted July 22, 2015 I actually just set mine up the same way a few weeks ago and am curious to see what other say. My z is a 75 and I believe the bracket is a bit different as my pump sits up a bit higher. Quote Link to comment Share on other sites More sharing options...
88dangerdan Posted July 22, 2015 Share Posted July 22, 2015 My .02, location is fine. But I'd put a 90° on the inlet side if possible. I'm not to familiar with that peticular pump if it will allow you to change connection. 1 Quote Link to comment Share on other sites More sharing options...
beermanpete Posted July 22, 2015 Share Posted July 22, 2015 We have a Holley fuel pump mounted the same way in our '73. It works fine. Quote Link to comment Share on other sites More sharing options...
Hypertek Posted July 22, 2015 Author Share Posted July 22, 2015 found this pic online, i guess i can put a 90 degree elbow on it just to give me more piece of mine lol http://i93.photobucket.com/albums/l62/injected99/FuelPump.jpg I was just unsure weather the 90 degree bend would affect flow as opposed to a curving hose. Quote Link to comment Share on other sites More sharing options...
88dangerdan Posted July 22, 2015 Share Posted July 22, 2015 With the 90°being on the inlet /suction side and it being such a short run. I would think it wouldn't cause any problems with restricting the flow. Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted July 22, 2015 Share Posted July 22, 2015 +1 on the 90. It's like a $5 part and will solve any issue you may think you'll have with the hose binding, kinking, or getting torn up. Quote Link to comment Share on other sites More sharing options...
Hypertek Posted July 24, 2015 Author Share Posted July 24, 2015 Im wondering where I can find that 90 degree fitting locally. Would prefer not going with a hardware store part with the multiple barb grips . Quote Link to comment Share on other sites More sharing options...
88dangerdan Posted July 24, 2015 Share Posted July 24, 2015 Where in CA.are you located? Fastenal is a good place. I might even have one or two lying around here. If you can't find one PM me your address and I'll send them to you. Daniel Quote Link to comment Share on other sites More sharing options...
