83 turbo ecu blinking rapidly under throttle and missing in high rpms
Hello i have a 76 280 with an l28et swap from an 83 zx.  recently the car has had a terrible miss in the high rpms once it is fully warmed up.  Also the ecu green led blinks 15-20 times in a 10 second period instead of the 5-10 it should (it used to)  the car will run WOT on boost up until about ~3750rpm then it just misses.  I did the resistance tests on the air flow meter, chts, and air temperature sensor and they all passed.  replaced the o2 this morning and id still runs badly.  the car also hates to cold start.  u have to crank and crank forever.
