Finding a Clutch Master that is Right
Haha.... So im not the only one who had this problem then? I spent 2 days bleeding the clutch system thinking I was doing it wrong... My solution was to take both U ends off the rods cut one in about half (horizontally) then mig weld them together extending the throw. Another thing you need to keep in mind if you do something like this is your clutch has to come back to rest at a certain point before it will build pressure when you step down. Again I would have swapped rods if the had a clip remover for that annoying retaining clip.
Thanks
