AZGhost623 Posted October 17, 2015 Share Posted October 17, 2015 (edited) First thought was a clifford research header, but i am not too sure... Its got some kind of EGT port on each exhaust port. Also told its got a 2.5" diameter. It came off a 240Z. And Im told its a square port. Im going to go check it out tomorrow morning. Edited October 17, 2015 by AZGhost623 Quote Link to comment Share on other sites More sharing options...
AZGhost623 Posted October 18, 2015 Author Share Posted October 18, 2015 So went and picked it up today, got it pretty cheap so no worries if its junk. Here are some additional pictures. Small dent on the rear #1 runner. Are the holes up on top something to do with emissions? Maybe some kind of EGT or O2 sensor ports? main pipe to muffler measures 2.25" runners measure 1.65" to the collector Exhaust ports 3 and 4 measure 38mm Exhaust ports 1, 2, 5 ,6 measure 30mm Quote Link to comment Share on other sites More sharing options...
NewZed Posted October 18, 2015 Share Posted October 18, 2015 Looks like a decent 240Z/260Z stock fit header. Equal length tubes, which are nice. I think that those are air injection port holes, so it's designed for street use, with the emissions air pump. Probably 72 - 74 240Z/260Z. Does it have the thick flange? That would be a clue. Many aftermarket headers use a thin flange which makes installation a pain. Quote Link to comment Share on other sites More sharing options...
AZGhost623 Posted October 18, 2015 Author Share Posted October 18, 2015 (edited) Yes. The flange is very thick. When you say "stock" like a Nissan part? Did they come from the factory with a header? Or was that a 'dealer option' of some sort? Edited October 18, 2015 by AZGhost623 Quote Link to comment Share on other sites More sharing options...
NewZed Posted October 18, 2015 Share Posted October 18, 2015 I meant designed to replace a stock manifold and maintain stock functions. Hence the air injection ports. A "track" header would probably not have those. Call it a street header. Quote Link to comment Share on other sites More sharing options...
NewZed Posted October 18, 2015 Share Posted October 18, 2015 Here's an example from MSA. Don't know it's only available in 3-2 configuration, but you can see the holes, and they're described. http://www.thezstore.com/page/TZS/PROD/15-6002 Quote Link to comment Share on other sites More sharing options...
Tony D Posted October 19, 2015 Share Posted October 19, 2015 They are the A.I.R. Fittings, for the parts off the stock mainfold to retain them. There was a time when all you had to do was keep emissions components in place and functioning and the part was legal. Now those are "illegal" in CA because they don't have a C.A.R.B. E.O. Number... go figure. What was legal is now illegal because they changed the process for new parts and didn't grandfather in existing parts. Sounds like "Some Animals are More Equal than Others..." Quote Link to comment Share on other sites More sharing options...
