Turbo260Z Posted March 14, 2016 Share Posted March 14, 2016 I have a 1974 early 260z with an l28et/ t5 swap. I already have MS3 so I can tune to a range of turbos. As well I have 370cc svo injectors and a 4bolt mandrel bent downpipe. I am looking to swap the original t3 turbo as the seals are bad and is starting to blow smoke now. What I would like is a t3/t4 internal wastegate, only oil cooled, and still retains the stock 4bolt downpipe. I, for some reason, cannot find a turbo with these specs. I am open to any turbo Along those lines so it will be the easiest to re install with little fabrication. Something quality. Thanks! P.s. A link to an exact turbo would be much appreciated. Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted March 14, 2016 Share Posted March 14, 2016 I don't think you'll have much luck with retaining that factory 4 bolt downpipe. I haven't seen any that have that. Quote Link to comment Share on other sites More sharing options...
Turbo260Z Posted March 14, 2016 Author Share Posted March 14, 2016 On 3/14/2016 at 8:08 PM, BluDestiny said: I don't think you'll have much luck with retaining that factory 4 bolt downpipe. I haven't seen any that have that. Anything that is along those lines without the downpipe? Was thinking of a 3ich v band Quote Link to comment Share on other sites More sharing options...
Namor Posted March 15, 2016 Share Posted March 15, 2016 (edited) I don't know about all turbos, but I bought a t3/t4e turbo from atpturbo.com and I had to make a new downpipe, add a spacer to the exhaust flange (the compressor housing is larger and hit the intake manifold if I didn't) and redo the intake plumbing (j-pipe no longer works) Oh and I had to make my own wastegate actuator mount. I would assume you will run into the same issue with any hybrid turbo. If you don't want to do the work to make a larger turbo fit, your best bet is probably to just have the stock turbo rebuilt. Edited March 15, 2016 by Namor Quote Link to comment Share on other sites More sharing options...
Turbo260Z Posted March 17, 2016 Author Share Posted March 17, 2016 Thanks! I think I blew the rings in my 6th cylinder. Thinking of a 2j now Quote Link to comment Share on other sites More sharing options...
