Where 83 L28et distributor round plug connect to?
^ I'm running a stock JDM 280zxet ecu. Yesterday, I told my mechanic to swap out the round plug for any generic plug or just solder the wires together and bypass the plug.
On to a different topic, I read on here and other sites that the 280zx brake booster will work on the 240z if you remove the aluminum spacer and turn it up-side-down. Well, it doesn't fit at all on my '72 240z.
1. The spacing of the studs on the 280zx booster are too wide.
2. The booster itself is too wide and hitting the clutch cylinder. So, my question is will an 8.5" '75-'78 280z brake booster works without any modification? Below is one I have in mind:
1975-1978 Nissan 280Z Brake Booster - A1 Cardone 53-5104
6634-05080017-1009290.jpgClick to Enlarge
(1 Reviews)
5 Stars
Our List Price:$90.33
Core Price [?]$22.50
Quantity:
ys.gif Select Year 1975 1976 1977 1978
In Stock
Availability: (7) In Stock
Condition: Remanufactured
Shipping Options: Ground
Part Number: 53-5104
Brand: A1 Cardone
Notes: Vacuum Booster -- Remanufactured; Without Master Cylinder; with 8-1/2" Diameter Booster
