Lockjaw Posted May 11, 2002 Share Posted May 11, 2002 Anyone got a rec on a relpacement coil for my 280ZXT. Need one that can handle increased boost pressure. I currently am using one of the little first gen 300ZX coils. It works pretty well, but I think it may be going bad. Is there anyway to test it? If my coil wire over to the distributor was arcing on my intercooler line, would that cause the coil to overheat and quit working? That is what I suspect happened. The coil was very hot and the car just loaded up at idle like they do when the alternator is bad and the battery runs down. Tach started bouncing around some and then the car would just die. I have an old HKS twin power ignition that I had to completely disconnect to get the thing to start, and thought that was the problem until it did it again with just the coil running. Thanks Quote Link to comment Share on other sites More sharing options...
Mike C Posted May 11, 2002 Share Posted May 11, 2002 I like the MSD blaster 2 coil and you can't beat te price at $30. Quote Link to comment Share on other sites More sharing options...
yo2001 Posted May 12, 2002 Share Posted May 12, 2002 Crane P91 is what I'm using. $50-$60 but it hasn't fail me yet. You can try mine to see how it does in your car if you want. Quote Link to comment Share on other sites More sharing options...
