Finned Cover for Long-Nose R200
74_5.0L_Z
  • 3 weeks later...
I might have one for you.
I gave it to a friend who was planning an r200 conversion, but he decided to use a Subaru R180. I'll see if he has any plans for it. It has been modified with an outlet for an oil cooler and two bungs for sensors (gauge and pump switch). Not sure if this is overkill for your application.
It's not a direct fit, but I have a spare Z32 finned cover if you're interested.
The cover to case bolts are in the same position.
The rear mounting bolts (mustache bar bolts) are farther apart which would require a modified mustache bar.
The mounting surface is about 1/2" closer to the case which could be solved with a simple spacer between the cover and the mustache bar.
