ZHoob2004 Posted August 25, 2017 Share Posted August 25, 2017 I recently purchased an F54/P79 motor that is presenting me with a few mysteries and I'm wondering if I can find any insight here. Here's the story so far: The motor was pulled from a 260z with a pair of flat-top SUs and a complete factory smog system (air pump and all) Was the p79 tapped for carbs still? The inside of the motor, aside from some significant carbon on the pistons, is like new. All bearings check out, the crosshatching is still present, no sludge, it's perfect. The cam has a "K" stamped in it, clear as day, and I've never heard of a K grind. Oh, and it has an elephant oil cap. Does anyone have any info about the K grind, such as where it comes from or what it is? I've seen a few mentions online but nothing substantial. Quote Link to comment Share on other sites More sharing options...
Zipper Posted August 25, 2017 Share Posted August 25, 2017 Here's another thread talking about a 'K' stamped P79 http://forums.hybridz.org/topic/57930-how-much-is-a-shaved-p90-worth/ That stamp isn't listed on the Atlanticz cam specs page. I just looked at couple heads I have here - have a 'B' marked P90 from a turbo (expected). And my P79 is blank. That 'K' looks like a similar font/marking style as the stock 'B' on my P90. My 260Z also has a F54/P79. Get it running (but maybe without the flat tops). Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted August 26, 2017 Share Posted August 26, 2017 Curious whether it is using a mechanical fuel pump since the most P79s are not cut for it. Quote Link to comment Share on other sites More sharing options...
ZHoob2004 Posted August 26, 2017 Author Share Posted August 26, 2017 (edited) Electric pump only. I don't think it ever ran very well with this setup, the pistons were caked in carbon and the carbs frozen. And in response to that other thread, it can't be an earlier cam because it's internally oiled Edited August 26, 2017 by ZHoob2004 Quote Link to comment Share on other sites More sharing options...
NewZed Posted August 28, 2017 Share Posted August 28, 2017 It's probably the "other" 280ZX grind. Check the FSM's and you'll find specs for a USA grind and a Canada. Engine Mechancial chapter. For some reason they stopped listing specs in 1983, but the 80-82 chapters show them. Quote Link to comment Share on other sites More sharing options...
