Chandler347 Posted February 24, 2018 Share Posted February 24, 2018 Wanted: 240z, 260z, or early model 280z. I need one with all glass and a body with no major damage. Rolling body with a dashboard is a big plus. Im located near sumter sc, and can have family look at cars near louisville ky.my max price range is 8k. Quote Link to comment Share on other sites More sharing options...
kevinz Posted March 10, 2018 Share Posted March 10, 2018 I have a 1975 280z roller. I’m located in Dallas/ft worth tx. I have all the parts for the car except for brake lines, fuel lines, carpet, and headliner. Car had brand new coilovers instslled. New poly bushings installed. New bearings front and rear. Bottom has been painted black. Bad dog frame rails installed. Disk brakes front and rear. LS1/4l60e with computer and harness already cleaned up and flashed. R200 lsd. Headers for swap. Radiator for swap. Engine and trans mounts for swap. Drive shaft for swap. Lots of other parts. I have an f54/p90 block and head also. My bottom dollar with LS drivetrain is 8500.00. If you didn’t want the LS and all of the swap parts then it would be substantially less. Call or text if you’d like. 817-733-4889. Kevin Quote Link to comment Share on other sites More sharing options...
240ZinAZ Posted May 11, 2020 Share Posted May 11, 2020 I'm probably a bit higher on what I want, and sounds like you didn't want a mostly-done project, but if you're still looking, take a peek at my project: https://offerup.com/item/detail/871693279/ Quote Link to comment Share on other sites More sharing options...
