Valve lash adjustment on aftermarket cam
turbogrill
Hi
I bought a cam used without cam card (shabolt m445, same as colt cams 542).
What should I set the valve lash to? Stock?
I read a post saying that a 0.001" change can affect timing up to 5degrees!
I checked the cam timing on cyl #1 intake, and its about right. I only have data floating around on internet so hard to make it exact.
Should I atleast make sure that all valves have the exact clearance?
What happens if its off? Premature wear?
Its for a race engine, someone told me to just make it as tigjt as possible. Not sure about that.
