M_Dragan Posted April 11, 2018 Share Posted April 11, 2018 Hi guys, I have a leak in my headers. I pulled them off on the weekend to replace the gaskets and I found that the heads appear to be the stock SBC square port but the headers are circular. The gasket I pulled off the headers are circular as well. Should I replace the gaskets with the same circular gaskets that were in there originally? I talked to a guy at summit and he said to match the gasket to the heads, the problem is that the square port gaskets are bigger corner to corner than the circular ones. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
marinez Posted June 24, 2018 Share Posted June 24, 2018 I suggest Remflex gaskets, matched to your heads. They should work fairly well as long as your flanges aren't warped. Quote Link to comment Share on other sites More sharing options...
Miles Posted June 25, 2018 Share Posted June 25, 2018 (edited) You didn't mention what type of headers you have. But you said that the headers are circular which suggests that you have block hugger style headers such as Hooker etc........................................ I have Hooker block hugger headers on my SBC 350. I have used the oval shaped header gasket for about 16 years. For example: https://www.summitracing.com/parts/mrg-5917 Other examples: https://www.holley.com/products/gaskets/header_gaskets/parts/10891HKR The attached picture is what I am currently using with my round port Hooker headers. Edited June 25, 2018 by Miles Quote Link to comment Share on other sites More sharing options...
Miles Posted August 27, 2018 Share Posted August 27, 2018 Here is another possible solution: Remflex graphite exhaust gasket p/n 2004 fits SBC 350 https://www.summitracing.com/parts/rfl-2004?cm_mmc=ppc-google-_-search-_-brands-_-keyword&gclid=CjwKCAjwwo7cBRBwEiwAMEoXPO0p6x0IaE3z78g6S_WaqfsQ62XlYavgtN0P7ds9oKQ2nkgcYqvh4xoCzkYQAvD_BwE Quote Link to comment Share on other sites More sharing options...
