seattlejester Posted May 14, 2018 Share Posted May 14, 2018 Hey guys, Kind of a random request. Does someone with a 1971 or 1972 240Z have easy access to measure the length from the firewall to the bolt holes of the stock cross member? Just in a forward to aft measurement like straight from the trans crossmember bolt hole to the firewall if say you put a piece of wood or something that spans the tunnel gap. It should be between 16 inches to 23 inches. I'm thinking it is almost in the middle of that at 19.5 inches. Quote Link to comment Share on other sites More sharing options...
Zetsaz Posted May 14, 2018 Share Posted May 14, 2018 If you don't get a response you can give me what you have from the bolt holes to that piece, and I can add that measurement to another from firewall to the cut we made. Quote Link to comment Share on other sites More sharing options...
seattlejester Posted May 14, 2018 Author Share Posted May 14, 2018 It would have been so easy to grab it before I cut the tunnel out...I was just so tired though that it slipped my mind. I think that won't work as I trimmed the panel quite a bit so I doubt the pieces will fit. I really need to just crawl under the car and find out. Quote Link to comment Share on other sites More sharing options...
