BJSZED Posted May 24, 2018 Share Posted May 24, 2018 (edited) Looking for wisdom on whether I need a resistor, diode or both on my alternator upgrade ? I know I need the diode to prevent run on after the ignition switch is turned off but am unsure of the reason for the resistor ? - 1972 240z - 90 amp maxima alternator - new speedhut voltmeter which does not use a light ( for the resistance on the ignition circuit ) - new wiring, old voltage regulator is gone thanks for your input ! Edited May 24, 2018 by BJSZED Quote Link to comment Share on other sites More sharing options...
NewZed Posted May 24, 2018 Share Posted May 24, 2018 4 hours ago, BJSZED said: I know I need the diode to prevent run on after the ignition switch is turned off but am unsure of the reason for the resistor ? Where did you get the thought that you need a resistor? Quote Link to comment Share on other sites More sharing options...
BJSZED Posted May 24, 2018 Author Share Posted May 24, 2018 I've been reading on-line and getting confused. I think the resistor comes into play on a 4 wire alternator. It is used instead of an alternator charge light. Without it apparently it won't charge at idle. I believe I just need the diode on the run/start ignition wire from the ignition switch to the alternator. Quote Link to comment Share on other sites More sharing options...
NewZed Posted May 24, 2018 Share Posted May 24, 2018 The diode goes on the L wire. Are you sure the Speedhut meter doesn't have a charge warning light? Either way, you should be able to use the typical 240Z alt swap wiring instructions. But, it's actually pretty simple. Study what the S and L wires actually do, and just wire according to function. Quote Link to comment Share on other sites More sharing options...
NewZed Posted May 24, 2018 Share Posted May 24, 2018 Do the swaps one at a time also or you might not know which swap is causing problem, voltmeter or alternator. Quote Link to comment Share on other sites More sharing options...
BJSZED Posted May 24, 2018 Author Share Posted May 24, 2018 Thanks for your responses...good advice, will do Quote Link to comment Share on other sites More sharing options...
