Superj243
Spent 6 hours today with a Dremel Tool carefully grinding away aluminum in the transmission housing right above the first clutch pack because the metal plate wouldn't fit. The old housing had a slot in it, the new one did not. I was wondering if anyone else has ran into this. New housing is from Cobra Transmissions.
Hello, it seems you have posted in the FAQ section which does not allow for replies. Please take a moment to verify you are in the forum section instead of the FAQ's for responses to be allowed. I've moved your post into the drive train section so hopefully someone can respond.
