Posted (edited)
i started with eibach lowereing springs and tokico shock and struts. then went with ground control weld-in coilovers up front and just cut a rear coil in the back. now i have techno toys coil overs all around. i have nothing bad to say about all their products. if you have or ever do a v8 swap in it then the rear springs will NEED to be stiffer, the car squats real good especially with any v8
i did use coilovers from a 240sx(i forget which year but there is topics on it), they will only fit the rear. they might be fine if you dont have alot of horsepower but i found that it cut down on the amount of travel the rear had and i was bottoming out the coilover when i launched hard.
Edited by G-Tech
Share this post
Link to post
