Anyone tried the R1 Concepts rotor kits?
The fact that they have a 5 lug floating rotor, along with a caliper that I'm about 99% sure is not a direct bolt on for the 240z, doesn't instill a lot of confidence that the items will fit properly. It may just be generic stock photos that they use, but that doesn't help as a selling point. I have no experience with them, but brakes are typically not an item I try to cheap out on. The stock brakes are decent in most applications, once the system has been gone through and restored (new rubber brake lines, fresh fluid, sealed system with no leaks, properly adjusted drums, good set of pads of front, properly functioning check valve in brake booster, etc). And if you're wanting to build a track warrior, then I'd recommend to upgrade to a tried and proven brake system. But if you want to be the first to leave a review with them, don't let me stop you.
