73 240z steering wheel shakes
  • 1 month later...
Rotate the front tires to the rear, that is an easy check. If you replaced the rack then I am guessing you replaced the rod ends? The Z steering linkage isn't too complicated, if you follow the route from the wheels back to steering wheel there are only a few things that can cause a shimmy or shake. If you let go of the steering wheel can you feel a shake in the seat/floor?
