280zzzzz Posted July 12, 2020 Share Posted July 12, 2020 Aug 76 280Z - Car runs good, stock chassis wiring. Voltage Gauge stopped working, any trouble shooting tips will be appreciated. Gauge tests OK... Quote Link to comment Share on other sites More sharing options...
NewZed Posted July 12, 2020 Share Posted July 12, 2020 Consult the wiring diagram. Quote Link to comment Share on other sites More sharing options...
jhm Posted July 12, 2020 Share Posted July 12, 2020 Yeah, if the gauge is working correctly, then the problem is most likely in the wiring harness, as NewZed suggested. Start with the dash harness and test your connections with a multimeter. Very easy for these old connectors to begin to fail, or have a dirty connection at the terminal plugs. Poor grounds are very often the cause of electrical issues in the S30. If you conduct all your troubleshooting and still haven't resolved the issue, you can always take the easy way out and rewire your gauge into a functional switched 12V circuit and be done with it. If you don't have the FSM for your vehicle yet, you can download all years for free at http://www.xenonzcar.com/. Quote Link to comment Share on other sites More sharing options...
280zzzzz Posted July 17, 2020 Author Share Posted July 17, 2020 On 7/12/2020 at 3:16 PM, jhm said: Yeah, if the gauge is working correctly, then the problem is most likely in the wiring harness, as NewZed suggested. Start with the dash harness and test your connections with a multimeter. Very easy for these old connectors to begin to fail, or have a dirty connection at the terminal plugs. Poor grounds are very often the cause of electrical issues in the S30. If you conduct all your troubleshooting and still haven't resolved the issue, you can always take the easy way out and rewire your gauge into a functional switched 12V circuit and be done with it. If you don't have the FSM for your vehicle yet, you can download all years for free at http://www.xenonzcar.com/. Expand Thanks Guys - Ya time to roll up sleeves and get in there...FSM in one hand... and translator from the humorist who wrote the manual to english in the other... Quote Link to comment Share on other sites More sharing options...
