fusion Posted December 22, 2020 Share Posted December 22, 2020 I am putting new rubber bushings in my rear control arms. The outer bushings have a metal sleeve inside that sticks out further on one side than the other. I am trying to remember which way they go back in. I believe the longer part of the sleeve faces outward, towards the spindle pin nuts. Is that correct? Quote Link to comment Share on other sites More sharing options...
NewZed Posted December 22, 2020 Share Posted December 22, 2020 There's a whole deep discussion about that over on CZCC. https://www.classiczcars.com/forums/topic/64195-rear-control-arm-bush-alignment/?tab=comments#comment-602505 Quote Link to comment Share on other sites More sharing options...
fusion Posted December 22, 2020 Author Share Posted December 22, 2020 Wow, thanks for the link. I did a bunch of searching but never came across that discussion. On a similar note, is there any good information on the rubber washers that go between the spindle and control arm? Can I just pick some up from a hardware store? I don't believe mine had any in there when I pulled everything apart. Quote Link to comment Share on other sites More sharing options...
