Wtb: Engine Block Breather Tube
Dat73z
If you come up empty...you can also simply tap the hole with a 1" NPT tap and screw in a 1" NPT to hose barb fitting. Just stuff a rag in the cavity to prevent chips from falling in the block or pull the pan and vacuum out the chips.
Edited by rossman
Thanks rossman, good suggestion for plan B.
