Dat73z Posted July 5, 2021 Share Posted July 5, 2021 I'm currently in the process of rebuilding some Q45 CV axles. They were packed with some brown goop prior. I have some heavy duty Lucas green stuff which I had used on Troy Ermish CVs a few times before. Since I probably won't be cracking these open again for a few years and they don't have grease fittings I figured I'd ask for some opinions. Does anyone have any recommendations on CV grease? Any insight on what works well (or doesn't hold up) would be appreciated! Quote Link to comment Share on other sites More sharing options...
Dat73z Posted July 5, 2021 Author Share Posted July 5, 2021 And a picture of how the unknown brown stuff held up 1 Quote Link to comment Share on other sites More sharing options...
Mayolives Posted July 5, 2021 Share Posted July 5, 2021 I have 944 style cv axles and a Quaife differential in my s30 road race car. It has big HP and TQ numbers. I used Valvoline Hi-Temp grease in them with no problems. I suspect most good grease brands, including the new synthetic greases will also do the job. Quote Link to comment Share on other sites More sharing options...
Dat73z Posted July 6, 2021 Author Share Posted July 6, 2021 19 hours ago, Mayolives said: I have 944 style cv axles and a Quaife differential in my s30 road race car. It has big HP and TQ numbers. I used Valvoline Hi-Temp grease in them with no problems. I suspect most good grease brands, including the new synthetic greases will also do the job. Thanks. Did you use the generic Valvoline synthetic moly grease? https://www.valvoline.com/our-products/grease-gear-oil/full-synthetic-grease After some more research it does sound like any off the shelf modern synthetic with moly would work well for CVs. Quote Link to comment Share on other sites More sharing options...
Mayolives Posted July 8, 2021 Share Posted July 8, 2021 I use the Valvoline generic. Quote Link to comment Share on other sites More sharing options...
Dat73z Posted August 4, 2021 Author Share Posted August 4, 2021 Thanks for the help. I ended up going with the Valvoline generic gray full synthetic. The local parts stores had maybe 6-8 options but only Valvoline and CRC were marked directly on the tube as Extreme Pressure and for use with CVs. Valvoline wasn't cheap at $20 per tube but the CRC was something like 2x the cost for the same volume. FSM for the Infinity Q45 showed 6.5-7oz per CV and each Valvoline tube was around 14oz so I sliced 2 tubes in half with a razor, half a tube for each CV. Quote Link to comment Share on other sites More sharing options...
