Panel gaps
fusion
I am preparing to paint my 1976 280z.  I am doing panel alignment and fitment while the body is still in primer so I can make adjustments if necessary.  I am looking for some panel gap numbers from people to get an idea of the ranges.  Even better if you have done your own panel fitment and adjustment.  A maximum and minimum if possible for each spot.  Looking for gap measurements on:
Fender to hood
Fender to door
Door to quarter panel
Hatch to body
Thanks in advance
Before I disassembled my Z I measured a few and took some pictures (this one was edited so you could actually read the numbers). Between the door and fenders I found my panel gaps were all falling around the 5.5mm range, and the hood and rear hatch gaps were a little smaller in the 2.5-3mm range.
  • 1 month later...
I put this off until now doing other things.  Would appreciate any additional measurements people have.  I plan to start from the back and work forward.
Fender to hood
Fender to door
Hatch to body
