Joe0690 Posted January 4 Share Posted January 4 Hi, im in the process of restomodding my 1971 240z. I am upgrading the suspension and changing to 5 bolt pattern to support 370z breaks and 17 inch tires. I also have a wide body kit to go more aggressive on tire width. my question is are stock 370z breaks good enough for track days? ( I’ll upgrade the fluid and pads to be high performance) Or do I need to upgrade the breaks further. the car will be 450-500hp at the crank (ls3) please let me know your thoughts. thank you Quote Link to comment Share on other sites More sharing options...
jhm Posted January 4 Share Posted January 4 I would say so, with the addition of the right pads and fluid (as you are already planning). Many of the 370s I see at the track are running stock brakes; but most have switched out to a better pad (e.g. Porterfield, Carbotech, etc) and a good high-temp synthetic fluid. Keep in the mind that the 370Z weighs close to 1000 lbs more than your 240. I ran the stock brakes on my car for track days a couple of years before upgrading....when upgraded with better pads/shoes/lines/fluid, the stock system is quite capable & well-balanced. So you should be in good shape with your upgrades, assuming they've been implemented correctly. Quote Link to comment Share on other sites More sharing options...
