FJOVA Posted April 6, 2023 Share Posted April 6, 2023 (edited) I am rebuilding a close ratio 5-speed from a 1981 280zx and I found the shift forks are worn -- though the brass/bronze contact points. Does anyone have a set that are in good condition that I could purchase? Thanks. Edited April 7, 2023 by FJOVA Quote Link to comment Share on other sites More sharing options...
NewZed Posted April 7, 2023 Share Posted April 7, 2023 A full set? Every fork? You might try putting a Wanted ad on Classiczcars.com. There a few guys over there that sell used parts. Quote Link to comment Share on other sites More sharing options...
FJOVA Posted April 7, 2023 Author Share Posted April 7, 2023 (edited) Thanks. A full set would be ideal but what I really need is 1&2 and 3&4. I will check out ClassicZCars.com. Edited April 8, 2023 by FJOVA Quote Link to comment Share on other sites More sharing options...
FJOVA Posted May 1, 2023 Author Share Posted May 1, 2023 (edited) I wanted to say thanks to everyone regarding this inquiry. I actually found new shift forks in Japan from a trading company and purchased them for an unbelievable price of $35/each delivered to the the US (part ##32811-58S10). I also found a VERY HELPFUL thread on classic zcars.com ... "FS5W71B Rebuild Thread - Tips tricks and discoveries!". A user "zKars" noted the following in his post... "...Ok, got a part today that is good news and confirms shift fork compatibility AND availability. One more Fs5W71B saved from the scrap heap. As it turns out part #32811-58S10 is the 3/4 shift fork from a Fs5W71C transmission. It is a usable replacement for both the 1-2 and 3-4 shift fork in FS5W71B with aluminum forks, and would also replace the 4 sp version metal forks. One tiny snag. The roll pin hole in the C and B type 5sp forks are larger than the 4 sp forks. If you break a 4 sp fork, you will need to drill the rod roll pine hole out to 0.195 or 15/64. A number 8 drill bit is good enough. Let me also repeat that the C type 1-2 shift fork will NOT WORK in the B types, it fits a larger diameter selector ring." Edited May 1, 2023 by FJOVA Quote Link to comment Share on other sites More sharing options...
