R180 Pinion preload
Fairlineguy
So my R180 diff is stripped and I’m replacing all the bearings .
Question is the item described as a crush tube actually a crush tube ?
I ask as mine had a shim under it which wouldn’t be required if it actually crushes secondly I see the tube in question is available in different sizes
Both make me think it doesn’t crush and you either fit shims or fit a different size tube to set the preload
Expand
You're right, it's more of a spacer than a crush tube. The shim is used to set pinion depth. There are a few active threads on this topic at classiczcars with a few folks there rebuilding their R180s.
Edited by Leon
